Airfilter Help Need A Pipe
right what I'm after is anyone or any companys that could make me a 12inch long pipe with one side 60mm outside diameter and then reduce it so the other side is 50mm outside diameter ??
Help?
  • Views 948
Hi, WHY? could you not just get straight pipe and increase one end outside diameter! you have not mentioned in side diameter...what would it be used for! would it have to be nice and colourfull!
do you know any places that could increse one end of a pipe for me?
and its for a airfilter from the 90" degree off the throttle body to the 45" degree attached to the airfilter
www.siliconhoses.com do elbow reducers in a range of internal diameters
thanks ill have a butchers
