Finaly Got Around To Checking My Brake Pads On My 6n
well was a bit shocked to see that the outer one on each side have more or less lost the left and right edges lol and there only half worn down.
Edited by dubbegood
  • Views 845
Don't look like those pads were sat right!
Good job you checked them now and not later!
Thats shocking letting them get into that state in the first place....
they look like they have been over cooked a few times causing the material to crack off, perhaps they were the scummiest components known to man or maybe the original pads to the car.
to be fair you get an advisory off an mot for low brake pads, so if your brakes work ok there should be no need to check the pads on a schedule as such.
the pads illustrated look like they have about +4mm of material left on them - id seriouslly think about using a better pad or a brake upgrade as such
Edited by bobby_hill
well only had the mot and a free brake check before mot towards the end of jan but past few days been thinking brakes didnt feel right and were making a weird noise now and then and these were ferrodo fads fitted when the last owner had the car.
I've now got some wurth branded brake pads fitted
