Painting Headlights
Gunna paint my headlights to look like
Is there any parts that sould be left and NOT painted?? (i know the back of the light cant, but what about the part at the bottom with the vertical lines?? and the where the indicator is??)
Gloss black best to use??
  • Replies 9
  • Views 1.4k
aslong as its not the reflective bits, iirc thats the only bit you cant paint.
yup, not the reflective bits.
Not sure if the glass on your headlights is sealed on but with mk3 lights, they're put in the oven to bake off!
smoked headlights are shite at night on country roads too!
I've got the lenses off already.
Got HID's aswel
The only bits I'm not sure if (but they are painted on that silver polo) is the part at the bottom of the main headlight which has the vertical lines. Not sure whether i can paint that or not
Is it best to use Gloss Black??
well if hes painted it you paint it, I'm sure you can get it off some way or another if its gay :-)
Plus i woudl use satin or matt, probbaly matt exhaust paint or something so it can withstand the heat
Thanks :thumbsup: Just i was reading some people have been using matt and some have been using gloss..... reckon there'd be much of a difference??
I would have thought he's used light tinting spray?
other than the gloss will be abit shinier if you look closely, if you can get high temp gloss go for it, personally i woudlnt do it anything but high temp just incase it goes get hot with the hids. :-)
i havn't got HID's but it still gets hot in there and i just used some plastikote paint and all the paint is still there lol
If that Polo's are the same as a Lupo then you can paint the whole inner plastic housing, including those lines, as you can see the actual inner light lense is still visible and therefore wouldnt affect the shine from the lights.
So what type of paint should i go for??
will i need to prime before hand or just jey it with wet and dry sandpaper??
Key it well with a Scotchbrite pad,then apply black vinyl bumper paint.
Its satin,and sticks better to hard plastics than a primer followed by panel paint,in my experiences.
Seems expensive at a tenner for a little can,but that's all you'll need.
