Steering Wheel Making Scratching Noise
as title says, steering wheel is making a scratching noise (some kind of friction) every time i turn and without music on its driving me insane!
i have a mk4 97 and would take the steering wheel off but cant seem to find any bolts to undo or anything!!
a little help..
thanks
Lowell
  • Views 1.2k
move the column up and down, hoover around all the gaps, it's usually just a bit of dirt. Happened to mine last year.
Look on the back of the steering wheel, you will see a metal ring with two contacts on. Put some spray, WD40 etc, on and it will cure it!
