Tyres Rubbing On Back
basically got my new wheels the other day and they came with tyres, which are HUGE i think 175 by something (i had 145's on the steels!) anyway fitted them today and went out shortly after with a car full and the tyres were rubbing like made and went on a bit and could smell burning rubber so stopped and turned around and drove home to put the steels back on,
it has dug in to the side wall quite a lot , i have been out tongiht hitting the inner arch at the rear up a bit so hopefully they wont rub, do you recon its safe to use the tyres as they are with the side wall as it is ?
will get some pics up later of the side walls
Edited by joestanton4
  • Replies 25
  • Views 1.8k
dont sound to safe to me lol,
but to be honest it happen to my mate he kept them on and they was fine,
just dont drive round fast or stupid cus if popped or when flat you would be fucked.
what car are you driving?
and what wheels? size etc?
No, I wouldn't recommend it.
Mine did the same, however, I was lucky and it only rubbed away a bit of the tread of the tire, not the sidewall.
If the sidewall is damaged, just run your steelies and get new tires mate as if you are running stretch or not, pressure is put onto that sidewall, and if it goes, it's just gonna cost you more in the long run.
i tryed my coupe 15" 195 with a 45 profile on my mk3 bredi and i couldnt even moove the car with them on the back lol
they wer fine on the front tho as long as i didnt brake too hard
haha happy days
car is a mk3 polo 1992
wheels are BBS RA'S 13's i think
pics
175/60/13's or 185/55/13's will fit without rubbing...
there not even that bad just look like you drove along the curb,
pics are crap , the top half of the STAR writing it not raised like the rest anymore , and its like that the whole way round on both tyres
i have 17" on my polo (bought it with them on) and i cant full lock as it makes such an embarrassing noise where it rubs, same for the rear bumps or people in the back it rubs, and its not even lowered yet.
I'm refurbishing 15" bbs ls now so get them on asap Id like to anyway.
my arch has a slight hole in the black plastic cover and worn some paint down..do i need a new one and do i need to get a touch up on that area to avoid rust or will it be ok?
Lower profile tyres/arch rolled/ camber shims.
Doesn't look that bad to me, I had a large groove in mine and they were fine.
But might aswell get some smaller tyres to stop the rubbing completely
will get some better pics in daylight tomorrow monring , i think they will be ok , and i cant afford to get new tyres atm
just dont want them to blow out on the motorway or anything
That doesn't look too bad to be fair, however, if you get pulled by a traffic copper, he may well give you 3 points for those tires. Don't quote me on this, but he may just do, depends who you get.
Other than that, they don't look as dangerous as you made them out to be as it's only the raised manufacturer mark, it's not actually taking the strength of the sidewall away.
I would advise you to get a piece of scaffolding pole and a heat gun and roll/pull your rear arches the jap way. There are 'nuff videos on youtube and is a good temp fix if you don't have the money to pay.
humm i think it would have to be a right ass of a copper to do me for that , migth look in to see how much new tyres are going to be
might just have to put the steels back on the back for a while.............
Is the paintwork on your polo excellent?
well before i started doing things on it , it was but now ..... far from it :oops: , i was thinking about rolling the arches , but knowing my luck it will be a bulls up and look worse
Well literally, all you need to do is:
Get a helpful mate willing to sit in the car and drive it slowly.
Jack up your car.
Heat up the arch with a heat gun in order for the paint to expand with the arch.
Stick the scaffolding pole closer to the rear of the car.
Drop the car back down.
Adjust the angle of the pole.
Get your mate to roll the car backwards and forwards until required roll/flare is achieved.
Mine came out alright but cracked the paint on one arch as we didn't heat up the arch, I'm not too bothered by this as for one, it's not overly noticeable and two, i wanted it resprayed, just gave me more incentive haha.
Jack up your car.
might give it a shot some time soon, or just not carry 4 people in my car lol
what do you recon the chances are of getting done by a copper for the sidewalls being like that?
the rear arches were full of rubber when i looked earlier on :lol:
Chances are slim for being pulled by that alone, seeing as your tyre will be rotating and the tyre isn't technically damaged.
It's just if you get pulled and they check them, they can be arsey.
would say "i had them checked by a garage and they said the structure of the sidewall wasent damaged and said it was ok to drive on them"
:lol:
if i were you i would run the steeliees until you can afford lower profile tyres, and as for the diy arch roling i would predict it will all end in tears, especially since the edge of the paint will be scratched off and eventully will most likely rust...
seems such a waste as the tyres that are on there atm are nearly new,
X2.
I ran some TSW Cylix on my mk2 bready quite afew years ago and managed to smooth the wriiting completely off both rear tyres! they were 185s iirc.
