How Do I Do Camber
can anyone tell me how i do rear camber on my mk4 polo its stressing me out :-) Thanks LIL-BROLO
  • Replies 11
  • Views 1.5k
hacksaw bladessss
where can u get camber shims from??
Let me google that for you!
Edited by polopete
you can either get camber shims from regal autosport,
or go pikey and use washers in one of the stub axle bolts
Not really that pikey seeing as it's used a lot in motorsport lol
Once you adjust camber you should adjust toe or your tyres won't last nearly as long.
Not really that easy on the rear!
never heard of it being used in motorsport would of thought people would have the money to spend £20 on shims!
At the end of the day putting a washer in outs all the stress on one bolt and this means its more likely to snap, you can also adjust the toe using shims, I'm not saying washer=death but shims is definitley the best option as it givesd you the option for adjustment
washers ftw :-D
not really, just use more washers for more camber, and less for less :lol:
Well, hacksaw blades rather than washers. Camber shims load the bolts up in the same way as anything else.
