80mm Will It Rub ? Mk4 6n
I'm looking into dropping my polo 80mm on front and probably 70 on the back. I'm going to be running standard steelies for a while and i just wanted to know if its going to rub ? And if so can i sort it out without going higher? e.g sorting inside of arches etc. Any advice would be great. or any picutres of lowering on standard steelies. Thanks jack
  • Views 777
you should be fine on standard steels, you could probable sit the car on the ground and it wouldnt scrub with standard steels
looks good mate , how much is that lowered by ?
