6n Airbag
Mint condistion including mounting frame.
  • Views 132
how hard was it to take out?
Not to much work, reliant on a torx25 spanner. Only problem is you need to bend the mounting rail slightly to get the glovebox to open and close comfortably, or else it just makes a grinding noise.
Will results in your airag light being constantly on unless you get one of them resisters.
Or get someone with VAG-COM to reset it :) Apparently.
I`m wanting to do this myself too.
