**NEW** Update On The Cloud Grey Bready - Picture Fragile :d.
Hai Guise :]
Basically, after sanding down my wheels, i found that the finish was no where near where i wanted it to be, i wanted it proper polished, but it doesnt even shine tbh :(
So instead, i shall be spraying them black with red tears :].
a while back i bought some frosted side repeaters, however, trying to fit them, the fittings just snapped, so i went to the scrappy, found a mk2 golf, got the side repeaters off, and basically just change the lenses (i didnt do it to my original ones incase i broke them :p)
and also fitted my new haxard switch :), mine was all broken before :]
and yes, ofcourse the bumpers are back on :), my car looks more..clothed? now :).
my dad helped grind the numberplate screws off as they were properly rusted ><.
this is the proper colour of my car :o
the pressed plates are now on, along with the 'Dubway' sticker :D.
alex.
Edited by Prox
  • Replies 45
  • Views 4.6k
Hai Guise :]
have u tryd hactualy polishing them ??
get some autosol
thell be like mirrors with a bit of elbo greas and some time :)
what grade wet n dry did you go up to?
:o Lies.
i worked on 1, proper loads. wet n dry from 200-320-400-600-800-1200 and it was still pitted, and just washing shining, used some duroglit? or something. it wasn't even getting better
alex
Bumpers FTL :thumbsdown:
:o Lies.
alex
if you still had pitting, you didn't use the course grades enough!
I have the same car in red for my 1st car :D
the wheels should look good black or if you get a good shine to them
Just imagine its your hair. You seem to put alot of time / effort into that just do that on the wheels :)
Needs more elbow grease for the wheels to shine take hours of each grade.
Edited by boomzor
Yeah I agree with the above. Don't spray them that's just taking the easy way out! Put some elbow grease in and start over, really take your time to work out the pits with lower grades. Or, if you still wanna take the easy way out, you can get them chrome powder coated.
i polished up a set of p slots a while back, started of by stripping paint, then sanding with some wet n dry then used a coarse rubbing compound and a thick bristle attachment on a drill, did make quite a mess granted but the results were good, and working through different rubbing compounds till i got down to some autosol, and gave a great shine.
heres a pic after about 30 mins work on one http://img519.imageshack.us/img519/9673/image005ba8.jpg
Edited by spence12345
Wow That Picture's Insane, I've Spent MUCH Longer On Just One and It Was No Way Near That.
But I'd Love a Finish Like That.
alex
^^ what polomon said.....sanding out the pitted metal at the beginning is the most important bit, as if you dont flat it back it will be really obvious the finer you go....if you want them to be seriously polished grab some 2000 and 2500 grit of ebay....works a treat with some autosol!
Okay, this Wednesday, ima have another go.
From looking at the top picture, can someone give me an detailed plan on what to do :)?
I know you've all said it, but I'm not sure how rough i should start on
thankyou guise, these wheels will not be sprayed black (Y)
alex.
Ide say start with 120....give the whole face a really decent rub down (be quite rough :biggrin: )! Make sure all parts are evenly and properly sanded intill all you can see is the scratch marks left from the 120 grit. Then move onto 240....your aim is to get rid of the 120 scratch marks intill you only have 240 scratch marks...then move up to 300/400....carry on like this intill you get to 800 when you should get some warm water with plenty of soapyness in it....lube up the wheel and carry on sanding as usual, remembering to rinse the sandpaper every now and again so it dosnt get clogged up....continue like this up intill 1500, give it a once over with 1500 (with soapy water like before), then dry it and apply some autosol....rub it in with the 1500 sandpaper and then leave it for a few minutes.....then buff all the autosol of with kitchen role.....it should be reeet shiney, the wheels that I have polished in the past have always turned out properly shiney when I've done this.....
Hope this works....if you fancy it being really shiney as fook then get hold of some 2000 and 2500 grit of ebay....
I Really appreciate your help.
I Will Post results at the end of wednesday.
thanks a lot. alex :)
get to work buddy!
looks good man!
I've been doing it a bit today
and got totally fed up, the pits weren't shifting
popped down to leeks to pick up some new electric sanding circles, and they worked a treat, got 80 for the roughest, then 120 and 240
done thta in one patch and already started looking good.
however, around the rim, and like, around the tears themselves, on the rim side, its really hard to get in there with sandpaper let alone the electric sander, but other than that I'm liking it :D.
more updates latah.
Alex
get some pics up
picspicpicspicspicspics
Got up to just 1500, more to come in the next few dayze :]
better irl tbh
Alex
They're coming along nicely :D
I will have to come round soon and help you out again
Just gotta give the wheels some asian persuasion and they will be shiny as you like soon ;)
Keep updates coming :D
amafagad, I'm in a good mood.
a. life is so good
b. i have a new mirror to take my OMGxSCENExCORE photo's in, aka, my wheels :D.
thought id take advantage of the weather and do something.
Went shopping, saw my girlfriend for a bit, saw the SICKEST mk1 golf (dreaaaam car much :])
and done some on my rims.
this is PRE-polish products :)
waiting for her to dry then whacking some Duro..c..glit* ;) (Yes i am 16 :D)
alex
Edit - Things To Come:
Red Tears, Red Surrounding The 'Volkswagen' Some HOT new Tyres :]
alex
Edited by Prox
Cool, Polish your wheels even more dude so its like an actual mirror will be worth it make your car get noticed more
yeaaah man, will do, going to get some 2k + 2.5k :]
Unfortunately, when doing the duroglit, somehow some water mixed with it, and therefor FAIL :(.
Alex
Edit:
Just ordered Some 2000 :]
Alex
Edited by Prox
Looking good bud! :)
High grade paper is going to finish them off ;)
