Gti Inlet Manifold & Throttle Fitted - 1 Small Problem
Ok, finally fitted the GTI inlet manifold and throttle body onto my 1.4 16v polo. Everything is working, the car accelerates etc. However the car is now finding it difficult to idle as the revs jump up n down the 1000 mark. Using my VAG COM i have one fault code that comes up:
- Barometeric / Manifold Pressure Signals: Implausible correlation P1553
I have used the channel 60 to do the adaptation run on the throttle body but no luck. Anyone have a clue what the error means and what can be the possible fault.
Cheers.
  • Views 659
May possibly need the ecu remapped? Maybe because the volume of air inside the manifold is higher?
