Cc Door Handles
I'm Wanting to spary my door handle white so its CC.
Which is the best way to do it as i dont want it to start flaking as you use them
Any 1 got any tips
  • Views 836
just do it the same as you would when you spray anything else, prep, prime, paint, rubbing compound and laquer. job done :thumbsup:
As above.
Make sure to fark you do light sprays, defo don't do a rush job on these. I'd recommend quite a few coats of every step as they will be touched regularly and will wear, so make sure you pile on the layers.
But remember, prep work is the key.
Edited by DubDanny
