Van Panels For A Mk2?
does anywhere sell them or is it a case of cutting them out of a breaker/making your own?
  • Views 1.3k
sticky back plastic behind the glass?
these are dicontinued, basicly are not for sale anymore, you'd be lucky to buy them second hand...your best bet is to make them yourself imo
oh thats a shame, so do u reckon spot welding a flat sheet of metal in would look ok or just like i've bodged the hell out of it?
I suspect your in the territory of it looking shit, I suppose if done neatly a flat piece could be welded in probably tacked in(not fully seam welded) with some seam sealer from the back. Trouble is stopping the metal from warping with the heat.
Most flat panels need a indented bead rolled in them to give them rigidity.
Why don't you try cutting perfect glass shaped sheet metal and just put them in with the window seals?
you wont fit a peice of steel with the window rubber as glass is about 3-4mm , bodywork steel is like 1.2mm or such
as said a flat piece will warp to buggery when its welded , needs some shaped stamped into it to give it strength
id prob try painting /vynil over the glass somehow , just accept theres a rubber there still
I'm sure Yeti off here knows were to get them from :)
one of my mates is a panel beater so he's gonna look at it saturday and see what he can do, will be using a spot welder to fit so there shouldn't be any heat warping!
but if someone does know where to get them that'd be great and soooo much less hassle
Edited by beany
