Moving The Number Plate Help.
how do I remove that sticky black stuff from behind the front number plate without damaging the paint work?
  • Replies 9
  • Views 1.9k
probably by heating it up, or tar remover
i think it would be the same way you'd get the black stuff from behind the rubstrips off :)
yeah would have thought so, I'm thinking of moving it to the bottom grille seen a few guys with it.
warm soapy water, elbow grease and tar remover?
thanks
hairdryer
how does that work?
You can get something called a caramel wheel, which is pretty much a rubber attached to a drill bit from a body suplly shop. Its designed for removing stuff like that without damaging paint or plastic. Dunno how much they are tho.
boil the kettle, then take it outside, then pour it over what u want taking offf and peel, CAREFULLY !
i was told fudge wheels can burn through paint easily
ahhh, what about tar remover, will that do much damage to the pain, but will it work, remove all of it.
I used to use caramel wheels at the refinishers i used to work at all the time, never had any paint damage. Although if your silly about it you can heat the wheel up too much which would rub the paint, but the wheel would remove the black stuff way before then.
