Common Problems With The Mk2 Polo
Hey
Couldnt find anything on other sites, so i thought id give this forum a go. I'm thinking of replacing my 6N with a MK2 as a bit of a project car. Was just wandering if anyone could give me some commonly known problems so i can look out for them when buying. (e.g. Where they corrode the most and common mechanical problems.)
  • Replies 10
  • Views 6.7k
I have written this out before,but i doubt id be able to find it in the search either. I dont have time at the moment,but rear box sections,rear seatbelt mounts,and rear chassis legs are rust areas. Sometimes battery trays,and front arches as well as rear.
Otherwise,nothing unusual springs to mind.
mechanically, the pierburg carbs (everyone knows) are well known for problems, answer to this is a webber carb replacement or a GT lump 8-)
I've had quite a few mk 2 polos and tbh they have been pretty solid, compared to most cars of same age
Cheers guys, the ones i have seen look pretty damn solid for their age. I was only concerned because I want to do my bit get another sorry looking polo back on the road (but dont want to spend all my time welding)
may have been said but...pierbur carb...nothing but problems....get a weber :thumbsup:
Well first corrosion
If it has any kind of plastic trim on the arches then it is most likely that there will be some corrosion under here (any small amount of bubbling you can see will represent a lot of rust) and if it doesn't then specifically check around and behind the front arches and the back one too where it meets the bumper.
The petrol tanks tend to be metal so you want to have a look around the filler neck where they often go
The battery bay is a notorious area for rust build up so take the battery out and have a poke in there.
As with any car you need to check the sills, the underside of the door edge, feel the carpets and check for moisture, check the boot around the catch and the edge below the catch. If you can get a look under the car.
Mechanical
Check to see what carbourettor it has, if it's a pierberg then it will most likely need to be replaced at some point for a weber (which aren't actually made any more!)
Other than that we've never had any problems with ours at all, although it is a good idea to keep a set of HT leads in your car as they do tend to go fairly regularly.
I've run mk2 Polos for 6 years. I've never had problems with the carb, but others certainly have.
The fuel tank has a design fault so rusts at the filler neck. This requires a new tank, which is £62.50 from gsf. Check when it was last done and budget/knock the price off if it hasn't been done recently.
Both my Polos had problems with stalling. This was due to faulty hall senders. Was easily fixed by buying a brand new distributor on e-bay for £55.
Apart from that these cars are tanks!
One advisory note however, is that VW stopped making body panels for the car just under 2 years ago so if you want 'genuine' replacement parts, these can be hard to find.
At the youngest, mk2s are now 19 years old so they certainly stand out on the road! :-)
As far as the pierburg carb goes they tend to need jets cleaned and the automatic part tends to make things more complicated.
I've discarded (put aside) two pierburgs and am running a weber DTMR now but now I know more about carbs reckon the two pierburgs just need a bit of attention. The pierburg tends to have idle problems in the cold weather which I'm sure would be fixable. The weber needs some knowledge to fit and also needs sourcing with the adaptor plate, not just a bolt on although an easy mod if your good with spanners.
A few ones to watch for me are battery tray, filler neck rust(which really means new tank) and rust on the valance (basically all the metal below the front grill gets many a stone chip).
Cheers guys, not point messing around with pierburg carbs by the sounds of it. I'm going to have a look at a few tommorow. Really shouldnt be getting one because I'm halfway through restoring an MG Midget and a 1984 Mini but you can never have too many projects can you :S
I've never really had any problems with the carb, except air leaks due to the rubber mount being perished. Just may be slightly temperamental when its really cold and can be prone to carb icing, where you will loose power and come to a halt, then you need to just wait a couple of minutes and it will be fine, however there are easy ways to modify the airbox if this does happen. Mine uses a lot of fuel on short journeys especially when its cold but its so cheap to run in every other way i don't really mind.
If you can try to find an early one (up to a C plate) that doesn't have the plastic sill trims, or if you do have a sill trim one take them off right away and treat any rust you find before its too late.
Love both of mine, just brilliant cars with so much character :-)
The instructions that come with them are pretty good so I found it didn't need too much prior knowledge to fit, I learnt quite a lot about carbs when we put it in. Though putting a weber carb in does raise the height of the air filter so we had to cut a hole out of the bonnet padding so that the bonnet would shut!
The carb on our Polo was OK untill the automatic choke kept on sticking, eventually it was just getting too bad so we we went for a weber carb.
