Last Of My Mk2 Polo Bits
i broke up a mk2 polo 1.0ltr breadvan a while back but still have lots of bits left
1.0 radiater SOLD
fan shroud £7
full wireing loom inc fuse box,fuses and relays £15
front and rear wiper arms £2 each
door seals £4 each
interior door handles,winder handles etc from the doors £misc
window regulaters £10 each
front q-lights £5 each
ignition module and coil £15 for both
distributer with vacum £10
front seat belts £15 the pair
all engine mounts £10 each
starter £10
radiater fan £10
expansion bottle £6
ashtray and heater surround £8
clocks with 58k £10
clocks surround £5
heater controls from inside the dash £5
1 rear bulb holder £3
fuel tank (nearly new) £25
fuel tank sender unit floor cover £3
rear and front shocks covers(round plastic bits) £1 each
horn £2
horn push from middle of steering wheel £3
interior mirror SOLD
handbrake lever £7
4 speed gear linkeage £15
standard grille SOLD
exhaust manifold heat riser plate £5
water hoses £2 each
down pipe clamp £2
a bag of tiny trim bits,bolts,rubber bits,plastic bits ask and i will check if its there
can post everything,what u needing!!!!!!!!!!
Edited by low bay
  • Replies 24
  • Views 1.2k
Has it got the little silver inserts that go in the door handles?
Ta
What was the engine code? I'm intrested in the thermostat housing depending on engine code and if its available.
no silver handle bitsin that stuff,are they the same as mk1 golf ones?if so i have some
can you send me a picture of the houseing?
did you get my PM (think it was on volkszone) about the no. plate light/ wing mirror cover etc?
cheers
mack
Do you still have the driver's side wingmirror?
do you have the rear number plate lights and do the clocks have a rev counter?
dan,no mirrors
no no. plate lights,standard clocks
Edited by low bay
someone must need some of these bits?????????????
I'm after a n/s front wing and headlamp
iff u still have them
pm me prices please
pm me prices please
i might have a headlight but no wings,will check
cheers dude :)
Hi do you have the steering rack and trackrods? If so how much posted? cheers Gavin
steering rack must have got binned as i cant find it
got a headlight for you portsmouth
how much for the loom posted?
could you give me a pm please
cheers
oli
all still here
have you got the huuuge Aerial or the window mechanism for passengers door?
PM MEH :)
Alex
if you have the full lamps for the rear number plate and they are in good condition i would be interested...
cheers
cheers
not sure but will check
up again for a fresh week
Do you have the triangular blanking plate for the passenger side mirror (inside)?
If so, PM me!
You still got the chrome/stainless inserts from the outer door handles ?
yes still here
yes still here
Are they dent & scratch free ? PM me with price & details
you still got the ignition module, coil & dizzy? and the loom that go with those bits
How much posted?
Edited by Cymro
