13"'s
will they clear g40 brakes?
  • Views 1.2k
depends on et mate... u usually have to run spacers...
13's are fine but i've just thrown a set of 8" alley cats on n needed spacers to clear the calipers...
just try it n see mate!
I take it the lower the ET the better then? I've got a set of 13x7 ET 10's that I'd quite like to run G40 brakes under. Think it'll work?
at the mo I'm planning refurbing some 6x13 classics , iv got mk1 gti brakes which same as g40 i think n they dont fit tho iv heard of people takeing a skim of the caliper with an angle grinder if you dont want spacers haha
I'm running 13 by 7 Alleycats and i have Mk2 golf disk's and calipers and with and ET of -7 they clear the brake calipers by around 1-2mm and my disk's just fit inside the wheel :lol:
it depends on the pad carrier - g40 ones had an added bar - but you can use std mk3 /late mk2 carriers
I used an angle grinder and 5mm spacers to get my old ATS classics to fit.
