Spraying Badges..
i wna spray all my badges black,
but I've looked at them all,
back and front and none of them look easy to take off,does anyone know how they come off ??,
and what will i need to do to spray them will i need primer and what not ??
thanks,
chris
  • Replies 8
  • Views 1.3k
Front one pulls out, is held by 3 clips if I remember correctly, just pull a good bit.
Rear one, heat up as though you're taking off the POLO badges or the bumpstrips and then peel off.
cheers m8 ill give it a go 2mora, what bout the polo badges and the one tht says 1.4 blah blah blah lol, tht one,
and do you know bout spraying them ??
Pretty sure the Polo badges etc can be pulled off with a bit of encouragment, not entirely sure about putting them back on though! I sprayed my front badge today, and as said above, it simply pulls out, might be a bit stiff.
In terms of paint, I used a spray can of acrylic (sp) and it seemed to work a treat. You might want to give the badges a light sanding beforehand or what not and your paint choice depends on what kind of finish you want. If you're spraying them remember to do several light layers rather than one heavy one.
The polo badges come off with a hairdryer and a card. Use the search function and search the term "debadging"
As for spraying, usually you'd want a matte colour to match the grille so if you go to your local shop and buy a can of matte black for outdoor purposes and some rubbing compund.
Get yourself something like a scouring pad (the green bit on the back of your mums sponges) then sand the badge back with this until it's dull and scratched lightly.
Then, apply the paint in light coats allowing drying time between each, then when all finished and dry. Apply rubbing compound lightly as instructed to get a smooth finish.
Make sure you don't spray the badges on a humid day as they will take longer to dry and the effect won't be as good.
cheers m8 ill grab a can from work,
will they need to be primered, or wil rubbing them down be enough ??
Shouldn't need to be primered, no. Mine have lasted a long time without it, it's just that when you get stone chips in it it will show the old stuff through, but with matte black, you can just give it a quick spray back over and jobs a good'n.
cheers m8, much appreciated,
ill let you know how i got on
