De Wipering 6n
How do u take the motor out of the boot bit for the rear wiper last time I did this the rear window smashed :|
take the boot trim panel off and you will see the bolts you need to remove, i did a write up on this with pics but mods decided it wasent good enough and didnt sticky it! GRRR!
I did take all the bolts out but it's stuck lol..can u send me the pics?send em to parmar_91@hotmail.co.uk
if there is just a screw sticking out from the window, then once you've un-done the bolts it should just pull out, maybe a little stiff though.
cheers people but now I've dne that where do i get the bit to cover it?I've got the standard bit with a grommet in it atm
By that do you mean something to fill the hole that's left?
Go to Halfords, they sell Grommets in a 3 pack.
think they come in 19 21 24 mm or something like that.
Then stick in which ever one fits, if it's a bit loose, ducktape it from the inside, or glue it in.
or if you stick a 10p piece in the hole in the original cover it fits perfectly then filler over that and spray it black! works well!
