Sell Scrap or Repair!
Hi all,
I hope somebody can give me some advice??
I have a P reg polo open air, with 50k on the clock, all works well but its now due for an mot and my friend told me that 2 bolts have snapped off the manifold!!
Its blowing from the manifold because there is a small gap! Apparently the bolts need to be drilled out of the cylinder head! I really don't know what to do!!
Any suggestions?? how much to fix it? should I just sell it or could I get any money for scraping it!!
Regards
Richard
  • Replies 15
  • Views 1.7k
Can you see if there is likely to be any of the bolts protruding from the head? If so, you could take the manifold off and then get some form of grips onto the rest of the stud. You might also be able to use some easy outs on it.
£20 each for a helicol insert (drill out and re seleved to the correct size), if u take it to an engineering place.
which manifold? inlet? or outlet. outlet should be a doddle.
as toby says if thers a bit still sticking out get some heat on it and WD etc.
Edited by genesisGT
Definately not a car to be scraping!!
Hi, thanks for replying so quick! me and my friend got the manifold off and there is nothing protruding! Its snapped off just inside the face if you get what I mean?
Richard
Hi, I'm not brilliant with cars but its at the front where the manifold presses the gasket against the cylinder head! Hope that makes sense!!
dont scrap it!! sell it to me!
look up a local engineers place, and ask how much for a helicol insert think its a 8mm? and do they do cars (engines still in it)
then take it to him and You take the manifold off and down pipe ( cheeper)
he then does the work (30mins - 1 hr each depending if he is taking the piss or not) then u put a new gasket on and fit the down pipe and drive it home.
about a mornings work and about £60 i recon all in.
Edited by genesisGT
Definately not worth scrapping!! Don't be silly :x Should get a mechanic to have a look, shouldn't cost too much as everyone else has said.
if you wanna be cleaver, try making a slot in the top of the screw, like a flat head screw and use a screwdriver to get it out, or if you have a hammer, and like a pin punch, tap it gently around always move the position of the pin.
I'm an engineer and this is how I deal with screw's stuck in a thread.
Like said above if you want an easy way out drill it out, pleantly of lub fluid, and take your time, then re-tap if needed, then isert a helicoil. and it should be fine.
defo not worth scrapping, iv had to have bits helicoiled on my car before, only cost me £40 per part (not per bolt)
are you mad ha? scrapping it? ill buy it though ha.
1. cant fail on a blowing manifold unless lambda reading is out.
2. if its one of them things that you just want doing, place a nut over top of the snapped bolt, get someone to get a nice bit of weld in the middle of the nut and onto snapped bolt and wind it out. simple. 10 minute job if you get a good weld on it.
Thanks a lot for all the advice people! Much appreciated! Just thought id ask, My polo is an open air model and the electric roof has just stopped working! Any idea where I can get a motor for it??
Are you sure it's not the switch because the motors are very epensive?
Yes I checked the switch and it seems to have power! I also checked the other end and there is also power! Must be the motor?
It opens with the piece of metal which you wind around but I really want to get it sorted!!
take the manifold off if you cant get them out buy wellding someing on them or moll grips then just pop the head off and get them drilled wouldent cost more then a 10 day 2 days work if you got the tools and no haw if not pay some one to do it probley looking at 150 quid tho
dont scrap it tho
good luck
loz
