Camber?
Hi all, just put my coilovers on at the weekend (cheers PhillJ), not iv got them wound right down to the bottom, but iv got serious camber issues at the mo, it looks really cool! i really like it as it stands!
But how long will my tyres last? I dont wont to be going throught tyres every week, what shall i do?
Cheers in advance!
Ohh and my exhaust rattles now when the engine is cold, not work, what could that be? and what will it be ratteling on?
Cheers!
  • Views 793
the only thing you can do is raise it up to solve the camber i think as you will go through a set of tires in about 1k miles seen as your tracking will be out after you've lowered it too.
Ahhh a small amount of camber like that induced when lowering the car wont make much diffrence at all mate ..
Get the tracking sorted yes but you should be fine with the camber ..
I have had a set of tyres on the rear of my car (for around 15K) which has camber on the rear slightly and they have warn less than the fronts
what sorta degrees of camber are we talkin about?
how long (estimate) will tyres last per degree?
try and set it by eye? slacken the lower strut bolts and move it about abit
