Door Cards
Mods please move if in wrong area..
Alright guys, the door card on my mk2 breaddy has ripped as has the part on the back. It's like a black sheet plastic. I'd like to know if there is a substitute for it because i'd like to replace it soon.
Regards,
  • Views 1.4k
tinfoil. lol should get ones from one of the top models liek i did, looks alot better!
Would the interior from a mk3 fit atall?
fronts should
It's the card at the back I'm more intrested in. Is there any alternatives, to re do it with. I would like to keep it looking original if possible.
regards,
Edited by Krookz
If you're a bit craft minded, there is a solution to this is the board itself isn't damaged. Strip as much of the damaged and loose original fabric off as you can and go to your local fabric shop. You want to try and get a non-synthetic or synthetic-natural blend fabric with at least a one directional stretch to it. Thinks like wool with lycra and some polycottons are suitable. You then need some adhesive, either get some spray on carpet tile contact adhesive, or some paint on stuff, Wickes own brand is quite good for this.
Cut out your fabric at least a couple of inches bigger than the panel you're covering, you can trim it back later to be tidier. Follow the instructions for whatever glue you get all over the visible side of the panel (after removing it and any handles, ashtrays, &c.) being sure to smooth out any creases and bubbles in the fabric. The stretch of the fabric helps you mould it over the form, you see. When you've done the front, put a little glue around the back of the board and be sure to fix the fabric well there. Once dry, refit all the removable trims, cutting holes with and X shape that runs to the corners for things like door release handles and ashtrays.
With a little trial and error you can get a very good finish in fabric over the original boards, I've done this a couple of times (sorry, no photographs on file :( ) As far as I know, originally the thin plastic fabric they use is applied with heat and shrunk to fit the form which makes it smart, but fragile and prone to damage after about 10 years as it becomes more brittle.
I hope this is a useful solution, or at least something to give you a few ideas.
Thank you, helped loads. Off to look at new fabric today.
Regards,
