New car....BIG problem
Ok, here's the deal.
Just over 24 hours ago I picked up my very clean and well cared for MY2001 Polo GTi
Tonight I'm swapping stuff from my old car into the new one. I put the keys to the Polo on the ledge of the lock on the hatchback door (mistake #1!), when I finished loading up I closed the door (mistake #2!!) without taking the keys out (mistake #3!!!) . Now, the keys are stuck between the door and the ledge. I've tried going in via the back seats but the keys are wedged tight. The dash board warning light shows the hatchback is open, but it's clearly not
Any ideas how to release the hatchback door, that doesn't involve loosening the hinges?
  • Replies 12
  • Views 1.5k
if you can get into the boot from inside the car the try taking off the back panel and popping the boot open with a screwdriver?
so you've locked them between the boot and the sill?
In a word 'Yes'
Sounds like a plan.
Do you know if the back panel is screwed on or 'popped' into place?
I know that in my 6N theres just one screw in the middle and then should pop off.
Cheers,
I'm going out right now to have a look!!!
this worked in my mk4 golf, so may work
unscrew the boot doorcard, screws will be awkard to unscrew in that position but it is possibile
then try pulling it off, if it does not come off you may need to remove the parcel shelf supports either side and then it should come off,
It will be difficult to pull of as it is ment to be removed when boot is open but tug it alot and it should snap off
then you will see the mechanism for the door,You need to pull one of the metal points and the boot opens.
Edited by Punz
bad times mate!
spare key ??
How many times have i nearly locked mine inside!!
You'll defiantely have to try popping the boot from the inside tho. SHould be possible.
Guys,
Thanks for all your replies. Keys have now been retrieved (thanks Mr RAC man!!) and the car up running. Only issue is that I must have knackered the lock in the process. Therefore I've got the number of a good auto lock smith who hopefully will be able to sort my 'issue' out.
