De wipered Mk3's
I'm thinking about de wipering the rear on my Mk3.
Anyone does this, easy, difficult?
Pictures?
Thanks.
  • Replies 14
  • Views 2.1k
Very easy job. All you have to do is unclip the cover on the inside of the bootlid. Unplug the connector to the wiper motor. Off the top of my head I think there are 2 or 3 bolts/nuts which you have to undo and the whole assembly drops out. Then just get a rubber bung from halfords to cover the whole. Job done, 30mins tops! If your rear washer works just plug the pipe with a bolt of kink it and cable tie it up.
Edited by jamesjuniorfizbob
Cheers! :) Don't suppose you have any example photo's?
And rubber bung? :?
My old cl with it done, I dont think I've got a rubber bung sorry. Just pop into halfords and they do an assorted pack of bungs, its been a while since I removed mine but I think off the top of my head its a 24mm bung? Just measure it roughly before you take it off.
I just noticed I sprayed mine red to try and blend in a bit better...bit it didn't do a very good job
have done a couple of mine...
Thankyou! Looks like I'll be getting mine off in the near future. :)
Did you just use a rubber bung for this?
did mine today, never had any help or even seen anything to do it, was a peice of piss mate, cover off, 3 10mm nuts, unplug the power/earth etc lead off, pull off the water pipe. plug a screw into the pipe so u dont get a leak and sorted.
use a 1inch rubber bung to fill the hole. sorted!
i done mine today with a 25mm grommet from halfords its like £1.60
hope this helped
Smoothed :-)
Smoothed :-)
Very nice. What pipe is that? :)
hope this helped
This:
http://www.halfords.com/webapp/wcs/stores/...tegoryId_165562
Any photo's?
yeah there the ones they do them in a 1 pack aswell and its really easy to do i did it in about 15mins :-D
Just gone out and got one today, will be taking it off when a go to my Dads in a week on wednesday.
Gutted* Want to go now.
Your got any pictures of yours?
Done mine.
(The badge is gone for spraying, and it's getting cleaned tomorrow. Don't worry)
Edited by RobWhite1992
