Anybody ever used a universal central lockin kit
As above I've got a 6n 1.4l and some tw@ bodged my door lock so there is no barrel has any one got any recomendations? Also if any one uses door poppers are they any good
Edited by wheelmanWayne
  • Replies 8
  • Views 934
take the good lock put it on the drivers side fill the hole for the lock in the other one and fit a universal locking kit , i have already fited one to my 6n but can remove to make a build thread if require, where are u based ? i can help u fit it as we are both birmz boys
Edited by veedub123
rclick.co.uk do a half decent one. It has some solonoids (or something like that) which attach to the rods on inside of the door. got the kit for the missus mx5, its a treat. not sure how easy to fit on a 6n tho....
Would of thought would be pretty easy to get a door from a scrappy? or, again, on rclick.co.uk, get the remote kit, it plugs straight into the central locking pump on a 6n, and then you dont need a door lock anymore. its about £40 i think.
i got mine from maplin electronics 20 quid
I have had 2 and have had trouble with both of them, sometime only one works, sometimes one has stopped working and I have had to replace it
although my mate bought one and had it fitted by his alarm fitter and its worked perfect for almost a year.
i have had 3 on 3 different cars always worked great just need to know how to fit them right
I think its does depend on the fitting, the one in my car was already fitted by previous owner and had lots issues with it, the other kit had some moisture in the door and I think that messed it up
the car dont have central locking so i want em either way!
I'm in acocks green mate I'm guna swap the barrels over tonight thanks for the offer I'm sure i can fit it myself with little hassel but if i do get stuck ill give you a shout mate lol nice1
Volksbits.com do a kit for £30 any good??????
and can i use the same kit for the boot?
maplin is cheeper at 25 , and i can get them for 13 on the bay aparantly
