g40 decat pipe
its a std downpipe with the cat chopped off and a pipe with lambda boss welded in. Not neatest but does the job. Mates to a standard system .£35IMG_2263.jpg
  • Views 244
would this fit on a 1L?
it will with a g40 manifold and is significantly larger bore that 1litre
I can get hold of one but it has a broken stud!
does it need the manifold for fitting to a GT?
yes - bigger bore, can probably get one fro £20 tho
bump
