Cam belt oopsie!
Well my sisters fella was using my p reg runaround to run some errands when unfortunately the cambelt has snapped. - Is the engine likely to be shagged or is there lots of clearance in the 1.4 engines? secondly - if theres a good chance the engine is shagged is there a better option to go for when selecting another lump? eventual plans are to tidy up the bay a bit and find some bike carbs from somewhere and get some fresh paint n rims around it to get it lookin half decent. I paid naff all for it and its solid as hell... it would certainly be a shame to scrap it anyway!
  • Replies 10
  • Views 1k
I'd say it depends on what he was doing when the belt snapped. In all likely hood, theres gonna be abit of a mess under the bonnet!!
i assume you have the 8v 1.4 engine? Could always go for a 16v engine
Like you say it depends whether the pistons can actually hit the valves. I've had 8v older VW engines where that can't happen for sure. Probably worth turning the engine over with a spanner on the crank pulley bolt and seeing whether you can get it to turn for a couple of revolutions.
Failing that you can get a 2nd hand engine and fit it without too much trouble if you are remotely handy with a set of tools. Certainly wouldn't be looking to scrap it..
No point turning it over by hand as the damage is already done. Need to do a compression test really, and you can hear when an engine has no compression as it has no rythem, and the starter motor sounds like its working faster because of no load on it.
You might be lucky and get away with needing a few new valves or all 8 even, but unlucky could mean a fooked bottom end too, u wont know till the head is off.
I disagree.
If he turns the bottom end over without the belt on he'll be able to establish whether or not valve contact is possible with his engine. If there is no contact it's worth fitting a belt and turning it over to see if he got lucky. If you hear contact then the head may as well come off for a repair or replacement because damage is 99% certain.
I know this because my old Golf Driver threw it's belt at about 5k rpm. I was lucky enough to have an engine where the pistons and valves couldn't meet. I'd have been pretty annoyed to have made the effort to remove the head only to find out there was no damage.
You could carry out a compression test but if contact has occurred it will just increase the damage/expense.
sounds more like a monumental fuck-up rather than an 'oopsie' lol
I agree with timing it up and sticking a new belt on as you can be lucky, but a 1.4 8v in a mk4 polo is definatly an interferance (sp!) engine (used to work for vw, see it all the time) so the likelyhood is that it will need valves/head.
Also if contact has occured the damage cant get any worse on a compression test tbh as once a valve is bent out of the way it wont make contact anymore, it might a tiny abit but not enough to do more damage than what has been done.
Well if you know there's going to have been interference as you do (you never said!) then I would say try it but be prepared to get ready for an overhaul of some sort. Unlucky.
Sorry, my bad! lol
Forgiven. ;)
Well I've seen the engines sell for 100-150 sheets on ebay..might be worth just picking one up save pissing around with an engine thats probably fooked..... will give me a chance to paint the bay and tidy it up a little while engine is out..
what other lumps fit? and what are my options with regard to carbs/tb's? I've never ever owned a polo before so i know sod all about what people do with them engine wise lol
oh yea, sorry this isnt in the engine section :p
