Tool for splitting BBS Polo GTi Wheels
Hey!
Iv got a bit of spare time coming up so I'm going to refurb my BBS polo gti wheels.
Does anyone know what the tool is called that i need to split them? and also where i can get it from? :)
any other tips on refurbing these are welcome! :)
Many thanks!
  • Replies 19
  • Views 2.7k
Hey!
Many thanks!
i read somewhere that you can use a scissor jack, pretty sure that worked for them but not sure on the details, have a search. James
just use a mallet, wont damage the lips but it will need a coule of strong hits before it starts to come off
cheers guys but i mean the actual tool to undo the bolts that connect the two pieces together :)
i think its called a torque or a star drive
i did mine, check it out if you want
good luck!!
spline tool.
excellent!! :thumbsup: :)
specific size? or will i generally have to buy a set?
you can buy them single in decent tool shops.
as far as size i do not know, they are sized in millimetres - so i guess you best bet is to measure the point to point in your screw head then measure the OD of the socket or bit you intend to buy.
halfords do a rail of these.
also called XZN bits and "triple square"
Thank you very much for your help! :)
i can vouch that the halfords ones are up to the job! from memory i think its the m8 spline you need. dont bother with the cheapo splines you can get, they will just snap and knacker up the bolt heads, plus you will need a torque wrench when putting them back together, and they are commonly 1/2" drive.
It is indeed an M8 and you can get sets chep on eBay from Laser that will do it just fine.
isn`t the 8mm is the one for driveshaft bolts. i am 98 % sure
edit - dunno either they could be the same size - but I'm sure they are around 12mm
Edited by bobby_hill
I think it is a 12mm aswell, halfrauds sell individual bits aswell, I bought just the one for about £2
Is that tool the same as the driveshaft one i use on my mk2?
8mm spline is common on Vag cars, unless someone has changed the screws for a 6mm allen hex cap screws - like i have the habit of doing when they round off slightly as i have an endless supply of these from work.
any pic of the wheels??
what should they be torque'd up to?
cheers guys :) shall get on it!
wheels are same as yours gti mark except corroded! (unless yours are 16's) have no pics at present.
