Cambers
Hi all, right i have lowered my mk 5 polo and put alloys on it. And the angle of the wheel is turned in from the top end of each wheel, any ideas of how to straighten them up without raising it? I have only lowered it around 60mm.
  • Views 1.2k
Dunno whether it's the same on the MK5 as the MK4 but all you have to do is undo the two strut bolts attaching the suspension arm to the control arms etc. and pull the disc towards you while tightening them back up. Job done! Make sure there tight though, you dont wanna be cornering and it falls back again because thats a bummer! Might need to get tracking done aswell probably to stop you tyres eating away.
same as the mk4^^
You will need to get the tracking done if you change the camber
why?
it will send it all out buy moveing it ie lowering a camber get it done someing on proper equitment and not haveing it set up proper will handel like shit
camber is some thing you need to get set up with gauges, you cannot guess it or 'eye' it accurately and as mentioned above lowering puts tracking out and any camber adjustment also puts tracking out.
so get the camber done first then get it tracked.
best to get it tracked mate, you can try to do it you are self but theres a high chance the wheel will sit bent causing you uneven tyre wear
