Replacing door seal and weather seal 6n
Does anybody know how to replace the door seal and weather seal on the 6n? Is it glued on? It looks as if it's part of the interior. I'm afraid I'm going to rip it apart if I pull it out too much. Same questions for the weather strip.
  • Views 918
if you mean the black rubber door shut seal with the grey trim inside then it just pulls straight off, might take a bit of force but it comes off easy enough
what do you mean by weather strip?
The extra bit of rubber on the top , right next to the door seal, but it stretches from the bonnet to the door gap. It's between the roof strip and the door seal and it's added protection from the rain. I'll get a picture tommorow if needed.
Can the trim be removed from the seal? It'd seem a bit silly if that wasn't possible.
the gutter trim does come out BUT I'm not entirely sure, i would imagine its clipped down and would lift out ut wait for some more answers before you go ripping it out.
new seals should have the cloth trim on them buddy surely? if not then the old ones could be removed and re glued to the new ones i guess
