Advice wanted regarding rust on my car.
Hi,
I'm planning on spending the following couple of months getting the Mk2 G reg Polo Coupe S I own back on the road. I plan in time on using the car full time and selling my current car. I've started with removing all the plastic on the car to see what's what an dit looks good and bad, so I'm after some advice :)
The rear's not too bad
The boot's got a nice dink...
Passenger door... a little bit of rust
Nearside wing... damn
Spot the section that is no longer attached where it's meant to be. This is the first of the 'important' parts I'd like to sort. Is there this section of panel available to buy?
Is the real nasty bit... the there is a hole underneath that tape.... a window out job. As you can see I have a bit of rust around the filler cap too...
I guess it could have been a lot worse.
Any advice on how to repair any of it would be great!
Cheers,
M
  • Views 1.2k
Any good with a welder ???
Make sure you chop all of the rust out before you weld a panels in as you will be doign it all over again in a years time ..
Stevie
I've never welded, but I know someone who can. Just spoke to them and they are asking if the panel is available, ie the whole area that includes the bonnet catch section? The hole in the inner wing will just have to be cut out and a new piece welded in its place though.
most of that should be doable with patches... but some might need bits cut from a donor car?
http://bap.dominohosting.biz/members/bap/b...ent&Ret=ALL
Most of that rust looks superficial, get it rubbed back to clean bare metal and treat it from there. The more serious stuff like the front panel should really be replaced if possible. The window surrounds can be worse than they look, but the only way to find out is to remove the window. Wings are bolt on and available for Mk2's
Hey cheers, for that. Will replace that front panel, seems the 'easiest' way forward. Will wait until I remove the engine to do all that. Would it be worth bracing across thethe front wings whilst the replacement panel is put into place?
Also, being from near Portsmouth, is there somewhere down this way to get body panels like that?
All mk2 panels except doors are obsolete from vw, so try a firm like hadrian body panels.
there is no cure for rust, all these rust away and treatment solutions are no use and will just return. The body shop that did mine cut corners on removing rust and low and behold its back.The only way round this as said above is to totally remove the rusting panel and weld/replace with new. This is something I'm also having problems with myself.
