To buy or not to buy?
Seen a ridicously low milage mk5 polo gti with leathers,the lot and very tempted to buy. But i fear it hasn't had the pedal box changed, is there any way of checking on the car if it has been done? (obviously i've asked the seller!) also, gearbox and cambelt have yet to be changed,(assures me its been checked and is showing no signs of wear) whats the average milage the gearbox's have been going? anything else i should look out for aswell? its a completly standard car so i don't think its been on the forum before.
  • Views 892
Gear boxes are usually at around 60k, although getting it checked out wouldnt do any harm.
better to get it checked over than having to buy a whole new gear box if it blows! (can be V. V. Expensive)
You can ring up your local dealer and give them the car reg, they will be able to tell you if it had the re call, there is no reason why it shouldnt have to be honest.
cars are generally not selling at the moment especially petrols so I'm sure you can get a good deal, trust your gut instinct i say!
the service book and sticker in the boot are marked to say if the pedal box recall has been carried out.
gearbox's.........dont believe everything you hear. they can go on for well over 100k. Or internally destruct in 13k
All depends on the driver, if you're pushing it past 4k day in and day out that's the least you can expect, as well as other problems.
