removing rear number plate...
right, i need to remove my rear number plate off my 6n... but where i thought i would find some screws are two plastic caps that i then thought would pull off, but the little suckers wouldn't budge? do i need to remove the boot trim and take it out from the insde?
cheers! :thumbsup: sorry if this seems a basic question, but you can't learn unless you ask!
  • Views 898
Just get a flat head screwdriver behind the plastic caps, they do come off.
Just get some pliers and turn and pull i did as my screws were shoot
yeah, pop the caps off, the skrews behind will proberly be rusted beond skrewing, take off all the plastic covering, mole grips should then unskrew them
:thumbsup:
