How to remove the steering wheel from a non airbag 6N
Hey everyone
I'm trying to remove the steering wheel on my 6N but cant work out how?
I've taken the middle bit but can't find anything else to take off can somebody please tell me how?
Thanks !
  • Views 891
From my Haynes manual:
Set wheels to front, ensure steering lock is off and indicator is in central position.
Prise off the horn button, note the position of the horn wiring then remove it from the wheel.
Mark the wheel and steering colum in relation to each other, the unscrew the nut and withdraw the steering wheel. If it is tight tap it up near the centre using the palm of your hand, or twist it from side to side whilst pulling upwards to release it. Remove the washers, where fitted.
Hope this helps?
Ben
Pop the horn cap off with a screw driver, then you have a plastic plate under that, pop that off as well. then you have a nut on the end of the steering collum, befour you take this off, make sure the steering is straight.
Nice 1 lads cheers for that done it now :thumbsup:
