How do I remove thw wings?
Hi all
I tried to remve the wings on the coupe today but got stuck. Undid the 4 bolts on the top, the little crew attached to the front rail. Removed the wheel lining and the two bolt inside the arck. Removed the bolt near the jacking point. The wing still seems to be holding on somewhere.
I am stuck. can anybody help?
Bolly
  • Views 838
the back edge is seriously stuck on with sealer , not 100% sure but i think mine has 3 bolts down the back edge ?
3 bolts on inner wing
3 - 5 top of wing under bonnet
1 on the sill
Not sure on a mk3 but you may want to remove the bumper on that side to make sure you've got everything undone
