NZ....
I know that its a 1.3 mpi, but was wondering what differences it has from a gt? How easy it would be to get up to gt power....and then beyond :p Is it as easy to gain power from as a gt? And how good are they in general, reliability etc? Cheers :)
  • Replies 11
  • Views 1.8k
In essence its an SPI engine with an mpi manifold bolted on both make 55bhp.
I would imagine you would need gt cam, gt dizzy then maybe GT ECU, injectors & AFM.
Edited by Cymro
lower comp different cam
you cant use a GT dizzy, or ecu on an NZ.
the NZ dizzy is one off, specific for NZ vacuum advanced ignition timing, with its own ecu and coil system.
but otherwise, as above, lower compression, different cam profile and obviously different map. 8P 5sp economy box also, no close ratios.
bloody annoying that, so it would be easier to do a GT conversion then.
Ah right....so its quite hard to make gt power then? ideally i want to make around 85 - 90 bhp....would this be feasible (sp) ? :)
Edited by Olly S
Basically the question is....NZ loon, or gt coupe? :lol:
gt coupe imo :thumbsup:
Thats what I'm thinking....but i do love loons :lol:
Loons are timlessly cool, but GT coupe! :-p
I wouldnt mind one myself tbh!
Haha yer I'm thinking its gona be a gt :lol: Il have to see whats about when i get some money together :)
so even if you added gt manifolds, exhaust, cam, g'box and whatever else it still wouldnt be putting out the same power as a standard gt?
just out of interest if the nz engine is the same power as the spi why did vw bother? lol is there any advantage over the spi?
Edited by mk3_nath
