Toe in
After many years of F'in around with my suspension the camber/tracking need majorly doing, but i cant do this due to the wheels toe'in in...
Has anyone adjusted this sort of thing before, do i adjust both sides or is one side fixed so it cant be adjusted?
Bloody baffled about this myself so hopefully someone can shed some light on this...
Ruined a set of tyres in the space of 4 months :(
  • Replies 17
  • Views 1.6k
Is this not just adjusting the track rods? I'm sure it is.. but someone can correct me.. The track rod (which goes into the back of your hub) is on a screw, you need to find out how much its out by though to adjust it properly.. Can't the garage that does the tracking not do it all?
They can but i prefre doing stuff myself, obviously i cant do the tracking etc... cos i need it on slidding plates...
I've got to have a string line from the back wheels going to the front and thats how i get them true.... apparently lol!
you change the toe setting by tracking the car up.......
i take it you mean front, and not rear
tracking, toe, alignment is all the same thing... its how far off parallel your front wheels are.sounds like same tyre depot somewhere has baffled you with science because their tracking boards dont fit over the wheels because the car is too low for them
camber is how far off 90 degrees your road wheel makes to the floor. can be easily adjusted, but if its majorly out you will need different bolts on the top of the strut to allow the camber to adjust further.
When the steering wheels straight, the front wheels... left wheel is toeing out ALOT! front left just a little...
But basicaly i have to do it myself somehow cos the cars too low for them to get the gear round the wheel!
So thats where I'm at, and baffled lol so looking for help!
i had a similar problem, the toe will be sorted when the tracking is done,
i found somewhere that would track my car even though it was very low (awesome gti)
just give some of the specialist vw places a ring
Where are awesome gti dude?
You knwo what, its getting to the point where id actually travel to get this sorted now! :lol:
Try one of the places listed here - http://www.alignmycar.co.uk/ their kit generally fits on any car.
I tend to DIY mk1/2/3 tracking because it's parrallel and +/-5 degrees, but I'm pretty sure mk4's are meant to run a bit of toe-in.
its in manchester, they were very good with me and tend to have an excellent reputation as they specialise in VAGs
find somewhere local with optical dunlop gauges as these do not fit over the wheels, they simply sit butted up against the wheel on the floor.....
no need to travel these modern computer monkey machines are all good with normal vehicles, but sometimes its best to go old skool...
might be an idea to adjust them somewhere close before going so they dont moan - then job done!
poundie, is your steering wheel straight when the steering lock comes on?
my local garage uses those guages and they only just reach past the bumper on my GT :lol:
some spillters do impare the operation hahaha
Dunlop gauges are not accurate. If you’re near west London visit Feltham tyres, they've done mine and check my ride height.
indeed s-line, 4 wheel laser track is best option by far, will need the camber set up first though.
If you can see how far they toe out then I would just do it by eye to get it somewhere near parallel until you can get somewhere to do it, at least it will save you some tyre wear. As for the camber I would get a straight edge on to the wheel / tyre vertically and just a basic spirit level. That should be enough to get you somewhere near but it will be far from perfect but at least you wont go through tyres as quick!
