chips and dents
so i brought a mk 3 polo last weekend very cheap of here woop so not expectng it tob tip top but as i polished it yesterday it just brought out evr chipdent n scratch so i was wondering woulld a body shop just go around paint them all or would i just have to get a full respray ???
cheers
  • Views 971
sorry about spelling literaly1st thing i done so far open eyes sort of n on here
how much do you want to spend
Just get some touch up paint and paint over the minor scratches, larger ones may need sanding and a coat of primer before overcoat.
You got any pictures?
Edited by Polo Will
erm about 80-100 and i can get some but some are just liek smalle stone chips but then uther are where they have tried to touch up n it luks awful and the dents are all aroud only a small then there is quite a lot on the sills as you open teh door and i dont no how to paint it if i samd it prime it then spray the excat color will yoiu be able to tell i have ??
If you look in your boot there should be a sticker with various bits of info on it. One of them should be your paint code. If you can find this out you should be able to determine what the exact colour of your car is. If the chips/scratches are only surface then primer then top coat should do the trick. If there's actual holes in the bodywork they will need to be filled which you might want to get done professionally.
Whether it'll be obvious to look at depends on how good a job you do. Spray painting it generally looks better but can be awkward for small areas.
Edited by Polo Will
