changing polo engine
alright I'm woundering if any body can help me....
I'm changing the engine in my polo frm a 1 litre to a 1.3 polo engine. I've been told that size and position is not the problem because the 1litre is a carb and the 1.3 is a injection the wiring will be different going into the ECU.
has anybody ever done this? and is it a easy job ? ill be greatful if anybody can help thanks scott.
  • Views 700
1.0 to a 1.3? not guna be a big difference that u know. if its for simplicity why not go to a 1.6? and as for the question, i thought that when changing polo engines about you had to swap key ecu and lot? are they not coded? possibly wrong just a thought
Yeah its a easy job to do. A lot of the information you need is here. Mk2 1.3 Carb to Mk3 1.3 GT Engine Conversion
