remote central locking kits - 6n
I have searched, but doesnt any body have any experiance with this specific kit:-
http://www.rclick.co.uk/product_info.php?c...products_id=480
The reason i ask is because it says its plyg and play, and i dont want to have to mess around with random cabling as i am sure i will go wrong.
How ever if anyone has other easy suggestions for remote central locking kits then please feel free to say.
Also is it easy to open the old key and take out the transponder, and then put it back in if i need to?
Is this transponder easy to brake accidently? :)
This is for a polo 6n aswell!
thanks.
  • Replies 31
  • Views 4.1k
its an awesome kit, i totally recommend it.
Plug and play is no exageration. You take harness out of central locking pump (in boot where first aid kit goes) and plug this kit in line, then back to pump. Thats it.
Range is good on the keys, and they are good quality, had mine a few years now.
Just need to put your imobiliser chip in the new key and get a blade cut.
the only extra stuff you may need to do:
Mine would lock when i pressed unlock, and vice versa. Use the wiring diagram provided with the kit, and there are two cables you need to swap to fix it, if you are bothered.
Also if you want your indicators to flash when you lock/unlock, you need to attach the cable to the right cable on your rear clusters. Not critical, and an easy job to do if you want to.
ah okay cool mate, um, is the imobiliser chip easy to take out?
and can you get a key cut in any normal key cutting shop?
I've got a brand new one of these for sale,
came yesterday but no longer need it.
£30 + p&p if you want it mate?
i took the chip out of a copied key rather than my original vw one. the copies usually have the chip in a little reb block which you can pull out of the key body. i would imagine you have to cut the vw key to pieces to get the chip out of it.
the blade, i got that cut at a local place for a few quid.
ah mate i already ordered it!
Ill let you know though as my mate might want one if this one works fine.
Does any body have an idea how the transponder chip comes out of an original VW key?
i would recommend leaving the original chip in the original key, you can get a key cut for £10-£20, and if you say you only really want the chip, he might do you just the chip copy for cheaper.
Who do you mean by "him" mate? Where could I get a chip copied and is it expensive?
Edited by haz_pro
him- the man behind the counter at the key cut place.
Mister minit, or most key cut places can copy chips. Got mine done in a shoe/key place in the back of sainsburys
ah i see, il look into this!
is it very expensive to get a chip copied?
i had a look in some shops today.
Both said they did not have the software, one said the chip was encrypted and could be copied.
How ever the other guy said he would have the software in a couple of weeks and it would cost roughly 70 pounds for the key to be cut and chip to be encoded.
Is this more then it should cost?
i think i will want both of the keys with the kit chipped and cut so hopefully they will do a deal for both.
bump
I was looking s this kit but for my 9n, but some1 said the flip key wouldnt work :? How would you transfer the key form your original to the new 1?? Or can you not??
hmm i dunno mate, i dont think you can transfer the key, but on the RC click website it has loads of replacement flick keys you can order.
Any one know how much it usually costs for a key to be cut and programmed?
Does this kit come with the transponder or not?
Does anyone know when the 6n was fitted with an immobiliser?
Does anyone know if I can swap the cheap flip key I've got from the rightclick keyless entry kit to a genuine VW one?
I see them going on ebay but not sure If I can programme them to work with an aftermarket kit,
The ones you get from right click look ok but just feel real cheap.
£70 for a key cut? explain to them that 1) you were not born yesterday, and that 2) you havnt came in on the last banana boat.
I paid £20 from a key cut place. the chip is nothing special and most places will be able to cut it. Try a few other places mate.
You cannot replace an rclick key with a vw key, the remote are totally different. a vw key will work with a vw kit, and an rclick kit with an rclick key. to be fair the rclick keys arnt the worst in the world, you get two with the kit, and if there is a problem (mine has lasted 2 years so far) you can buy a new key on the site for £7.
As far as i know all 6n's have a chip in the ignition, i have had a 95 and a 97 and both had chips in the keys. take your key to (pretty much) any key cut place and they can check if it has a chip in it or not.
What sort of range do you get on your rclick remotes?
I've just fitted mine with the control unit under the dash with the antenna fully extended and I'm only able to use the remotes within about 5-10 metres. Is this normal? cos with my past cars with factory remote C/L the range was much higher.
Edited by seanlbc187
I brought this kit and it arrived today. Literally plug and play!
Get your keys copied from any locksmiths, fit them into the fob (5 min job), take the immobilizer chip out of the old key and fit it into the fob.
JOB DONE!!
top job jon.brown
The range on mine is pretty good, i have it in the boot next to central locking pump, also have antenna sticking up where seat belt comes out of the rear trim.
The key definately has a chip, i got them to check, but he said he doesnt have the software to copy the chip. Also i think i need to find a few more places to get a key cut, as they said they dont have a laser cutter. :-(
JOB DONE!!
Where in the key is the chip located? would i be able to put the chip back easily if i wanted to?
Edited by haz_pro
laser cut? what mk you got? mines mk4, dont need laser cut for that. just your bog standard spinny blade thing will cut them keys. (or whatever it is called)
yeah mines a mk 4, its the same as the key in this photo:-
i guess i have been fed aload of rubbish then, its quite annoyed me to be honest!
any body know a reliable honest key cutter in the epsom area?
Which wires do you connect to make the indicators flash?
cant remeber off top of my head, its all in the instructions.
