Replacing front grille on MK3 polo
hey guys- iv just brought a sports mesh grille for my mk3 (1991-94) model polo......just had a look and cannot work out how to remove the old one?
does anyone know?
any help is appriciated :D
cheers
ben
  • Views 865
just push the 4 wee clips in with a screw driver along the top and slowly pull it forward !
they only hold on by a few mm.
should do the job.
thanks...il try that when my grille turns up....but- is the air intake thing behind it attaatched to the grille? I'm not sure...
thanks alot mate :D
ben
pmed you back!
its the cold air feed you car must be a NZ engine!
just pull the rectangle bit back towards the engine it will come off or undo the corigated plastic pipe bit .
