doors
are mk2 and mk3 doors the same :?
Nope correct me if I'm wrong
The same in what way?
Mk3 doors have side impact beams that mk2`s dont.
If you mean can you put mk3 doors on a mk2 & vice versa, then I've heard that you can.
Have you tried a search. I've seen this covered before
sorry, should've been more specific. yeh i meant are they the same fitment wise. didn't know about impact beams though!
they are, i tried a mk3 door on my old mk2 bready and they fit the same just the bumpstrips are different
Joe
Definitely the same fitting, the Mk2 and Mk3 body shells are pretty much identical apart from a few different holes here and there. In theory, you can change all the removable panels on a Mk2 for Mk3 panels, I've seen it done with the nose end but not the tail end before but I'm pretty sure it's a straightforward swap. The interiors are perfectly exchangable too. Sometimes, Mk3 gets called Mk2F because it was mostly a facelift of an older style.
I'm happy to be proved wrong on this one, of course, but I'm pretty sure I'm not.
They're both a second generation Polo,just the later one is a facelift. Only later facelift cars got side impact bars,i dont think they were on pre-93 cars,certainly not pre-92.
You dont want them though,they locked the door shut in a few reported accidents,and a young womans silver breadvan in Germany brought the problem to light when it took the German fire service over an hour to cut her out of it.
