more rust... really have no idea about this one!
Check it out...
it's taken from behind the rear right removable panel looking towards the fuel tank...
Doesn't look good does it!
Any advice?
Cheers,
M
  • Views 1.4k
not much your gona do with that bit around the hose...its not structural
the blistering on the on the other metal...can you get at it with wire brush or something and waxoil it
Unfortunately this is a really common grot spot on the MK1->3 shells, there used to be a steel pipe running from the inner arch through to the top of the fuel tank area with that breather hose running inside. Problem was that the steel pipe fills with water from the inner arch and then rots its way out and eventually will also rot your inner sills / jackin points out too.
I've got a neat fix though, so bear with me -
Buy a washing machine flexy hose from your DIY superstore, the ones that allow you to connect your washing machine to the taps, they are plastic flexible pipes with a rubber neck at one end (to go over the tap). You can enlarge the hole in the inner wing and use the washing machine hose to feed the breather pipe through, it'll never rust and a dab of sealant will secure it really well. Some pics:-
You can see the end of the washing machine hose poking out by the shock absorber, i've sealed it against the body with Tiger Seal.
Mine's been like that for a year and it's never leaked and can't rust either.
Edited by euro-derby
Hey, cheers for the info. I can see what you've done there, looks good!
I see that you've used a fair amount of hammerite(!) By the looks of it, you have painted over the top of what was there, am I correct? I was thinking of doing the same.
Cheers!
M
Cheers!
M
No worries, it's not Hammerite. The whole lot went back to bare steel, then reprimed with epoxy primer and Upol Gravitex over the top. This was followed by two coats of body colour and three coats of clear lacquer to protect the colour.
All of the original VW stuff went in the bin!
Hey, sorry to 'instult' you saying it was hammerite, there is as you describe a lot more work gone into that than a can and a paint brush! Looks great!
With regards the rusty pipe inside teh rear panel, did you just cut it away at the point of where it went through the panels?
Cheers,
M
No offence taken at all mate - sorry if i came across that way :oops:
Yep, chop the pipe clean away from either end - I used an old chisel to remove the remains (take the plastic pipe out!) Let me know how you get on with it.
