6N ABF
Just get it on coilies! £170 from me...
So is this all sweet now or has it still got probs?
  • Replies 151
  • Views 34.5k
  • matt-polo-6n
    matt-polo-6n
    About time for an update on this, things I've been upto; removed sunroof, made blanking panel out of sheet of aluminium and fitted with some sealant and rivets, interior has/is being replaced with a
  • matt-polo-6n
    matt-polo-6n
    started the front arches cut the piece of arch out causing the problem and sanded the wing arch extension and abit of "sticks like shit" arch extension stuck in place and some rivets just to be
  • This is turning out to be a great car!
Looking good mate :thumbsup:
dnt waste money on more springs just get coilovers then u can adjust, they r the answer!
don't waste money on engine rebuilds, just slap another in.
how much did the essentially full on rebuild cost?
its all sweet now, had a leaky radiator the other day but fixed it :thumbsup:
yeah thinking about just selling the kit I've got and getting coilovers, need to wait til i get paid though
id rather not say exactly how much it cost for the fact i dont want the thread to get over run with posts like "you should have had a transplant" etc etc
it wasnt cheap, but it was worth it.
problem I've got now is i want do the gti bottom end swap, but I've spent the money on the engine so its works properly...what to do ay? decisions decisions lol
Edited by matt-polo-6n
What other engine mods have you done though? I'd personally get a 4-2-1 with a straight through exhaust system, probably a poloace chip or something similar, and then maybe a BMC or K&N air filter to round it off, not sure what additional power you would see from that on a 16v but its worth considering before you go taking the engine out again, if your not happy with that power then go for it :thumbsup:
i havnt done any engine mods just yet,
cant decide what i want to do first lol
my thoughts are a 4-2-1, K&N and cams
but later on i want R1 throttle bodies so i dont know whether to save and do it all in one go or do little bits here and there but have to change things later on :?
started work on my boot build last night,
took a while to decide how i wanted it but got there in the end,
will post pics and keep updated as it comes along :)
finally finished my boot build, well not 100% finished, just need to decided what i want to cover it in, but its in the boot now lol
will get pics up of it later on when i get home,
had a few other things to get sorted aswell, idling problem has now been solved so it no longer revs by itself or stutters,
had new brakes fitted, wanted the g60 fronts but person never got back to me about doing a swap so went for ebc green stuff pads and ebc ultimax discs, the polo also now has wind deflectors, gti splitter and magnecor ht leads.
have a 4-2-1 and front upper strut brace waiting at home to fit and powerflex bushes on the way as the standards are abit buggered now lol
  • 10 months later...
Right, thought it was time for an update on this as its been a while to say the least!
All the engine problems were sorted (or so i was told) but it turned out that they werent, and on new years day the engine went and i was left with gapping hole through the 3rd piston :(
Anyway, bought myself a new engine and decided id had it with garages so time to get busy and learn for myself.
I bought the car completely standard as i wanted it to be my own creation as it were.
Current spec is:
Green Silicone Coolant Hoses
Polished Rocker Cover
Green Fuel Hose
Painted All Visible Engine Bolts White
Painted Fuel Rail White
Polished Gas Bonnet Lifts
8.5mm Magnecor HT Leads
Enclosed Simota Induction Kit
Gas Flowed Throttle Body
F.S.E Power Boost Valve
Oil Catch Tank
Oil Breather Filter
Removed EGR Valve
Stainless Steel 4-2-1 Manifold
Custom De-Catted Exhaust System
16v Fogs
6N2 GTI Splitter
Side Lights In Front Indicators
Clear Wing Indicators
Bump Strips Removed
Roof Painted VW Alpine White
Wing Mirrors Painted VW Alpine White
Stubby Aerial
6N2 Rear Lights
Front Callipers Painted White
Powerflex Front Arm Bushes
TA Technix Coilovers
Rear Upper Strut Brace
Pioneer DEH-7000UB Headunit
Vibe Slick S40's In Dash
Vibe Black Air 6 Components In Doors
Vibe Slick S12 Sub &
Vibe Slick A1 Amp In Custom Boot Build
Momo Team 280mm
Momo Airbag Boss
6N2 Gearknob
6N2 Handbrake
6N2 Door Pins
Salsa Green Colour Concept Seats
EBC Ultimax Front Discs
EBC GreenStuff Front Pads
14 x 6 RH Cups
Car went to Aldon Automotive on the 9th and produced 116bhp at 6210 rpm
Currently trying to find the time to fit the following:
OEM 6N Boot Spoiler
6N2 GTI Rear Disc Conversion
Camber Shims
R1 Throttle Bodies (on the lookout for a standalone ecu)
also waiting for a reply about a 6N2 GTI Bottom End :)
Pics to follow, just need to find the lead for my phone!
couple of pics on the rollers...
will get more up once had chance to give it a clean :)
  • 4 months later...
work on a abf conversion is now under way,
engine bay is fully stripped and and waiting for welding and new mounts, should be done by end of week,
dash is removed ready for spaghetti of loom to be sorted out,
just got clutch and driveshafts to have a think about, will post pics up as it stands at the min
orite pal. were you get your "F.S.E Power Boost Valve" and what does it do?
also did decatin it make a improvement?
cheers pal Danny
  • 2 years later...
Did you ever finish the ABF conversion?
yeah finished the conversion, eventually, took a whole lot longer than it should have done, partly due to being let down by some people, partly because i kept changing my mind about things every other week and i only got 3-4 hours of a saturday morning free to work on it.
car itself isnt finished as id like it, but its getting there
thread really needs a big update, have so many pics from along the way, its just finding the time to organise them all and do a write up
Looking good mate, I like the engine bay
Looking forward to update Then
You can also do a rear disc conversion with the mk2 golf gti stub axles, hubs, bearings and discs, the stub axles fit perfect and you can still keep the 4x100 hubs and disc's
her is mine with the mk2 setup
before i started on the abf conversion i bought a couple of goodies, momo team 280 and saved this interior from the scrappage scheme (update long over due)
bought a mk3 golf 2.0 16v gti donor car then started stripping the polo
lining up the engine ready to start making mounts
bought some g60's, drilled and grooved discs and green stuff pads
a set of rx2's
and some camber shims
rear engine mounts
some adjustments and capri v6 engine mount bushes
more updates a little later
engine in on rear mounts and a jack at the front to check alignment
front cross member knocked up
engine came back out for some sanding and spraying
engine back in
trial fitting front end
need to get to dipstick
bought some piper BP270 cams
and a new oil cap
changes to front end
fitting cams
hope the 8v rad copes with cooling
schmidt th lines 14 x 8 & 14 x 9, do fit over g60 brakes with 15mm spacers
made a start on wiring
bought some new goodies, braided lines, strut braces and neuspeed 28mm rear anti roll bar
sump was a little low for comfort
so bought a steel sump and thought why not to a windage tray
what awesome gti dont tell you when buying a steel sump for an abf is you also need to buy 17mm long bolts or use bolts from either the 2.0 8v or a tdi, something i discovered after i turned the key and ended up with a puddle of oil
more buying
lightened flywheel
braided fuel hose
decided to do a little porting to the throttle body
slowly getting there
dash back in
