6N ABF
Is this Adaptormans work??? Or did you get some inspiration from my red vr6 thread? Looks identical ha. Keep it up mate
  • Replies 151
  • Views 34.5k
  • matt-polo-6n
    matt-polo-6n
    About time for an update on this, things I've been upto; removed sunroof, made blanking panel out of sheet of aluminium and fitted with some sealant and rivets, interior has/is being replaced with a
  • matt-polo-6n
    matt-polo-6n
    started the front arches cut the piece of arch out causing the problem and sanded the wing arch extension and abit of "sticks like shit" arch extension stuck in place and some rivets just to be
  • This is turning out to be a great car!
Haha yeah your red vr6 thread had a part to play, some more updates to come later today
Looks cool man, When you thinking it will be all done? Well running :smile:
its running now, just not on the road yet, I'm forever changing and adding things so the list of jobs is just getting bigger and bigger
thought id try my hand at wrapping
and a double din conversion
Edited by matt-polo-6n
swapped fuel pump over to the abf item, needed a bit of messing around, was hoping to just swap the sender but wasnt able to
dash came back out and dropped it off at clever flockers, dash is so much nicer once flocked
was running on standard ecu, then bought a chip for that, then changed my mind again and bought a megasquirt kit
got the soldering iron out and made a start
after a few hours
still have a few things to finish off with the megasquirt, but have put that to one side for the time being
bought a us spec rear bench, was just black leather but wanted it matching my salsa green colour concepts, took the backs off and took the leather to retro retrims for some tweaking
addition of some depo's really makes a difference to the front
decided to do this to the inlet
to match these (16 x 8j & 16 x 9j)
with the inlet off i thought why not take the rocker off and show that some paint
work started on the exhaust
strut brace went back on
dont have any pics of exhaust as i went along but has 200 cell sport cat and straight through middle and backboxes, wasnt sure whether to have the middle box but at the same time didnt want it too loud
tail pipe (axle stand is just propping exhaust up before welding hangers on)
i decided to buy this, eaton m62, wasnt sure if id have the space at the front of the engine for it, but thought i'll see how it goes
as the m62 pulley wasnt much smaller than the abf crank pulley, i bought a g60 68mm pulley and adapted it to fit the m62
front end came off again so i could see where i was going to put the m62
started mocking up a rough bracket just to hold the m62 so i could check clearances
mounted m62 and outcome was a little gutting with no available space for outlet pipework
decided to scrap the m62 idea
interior is now for sale and on the lookout for some cobra monaco pro seats and harnesses
need to take some more pictures of where I'm up to now but waiting for a sunny weekend
take my hat off to you mate nice build,
I started a kr on bike carbs then turboed it a few years back but cba finishing it off loool changed idea and went 20vt in the end.
so for the wiring I take it you used the mk3 golf loom and fuse box as at first I seen the late polo fuse box if not mistaken.
Cheers mate
Yeah I swapped the loom and fusebox over to the golf ones, when I started it I didnt have a clue on the wiring side so I went with the logic of swapping the whole loom and fusebox over, that way it was just a case of plugging it all back in
Latest addition are polycarbonate windows, anyone know of the best stuff to use for bonding them in?
I used Tiger seal for the rear window but its not that good if I'm honest. I got autoglass out to fit rear quater windows and their mint. They primed round edge of windows in black and stuck them in for £40.
ahh cheers will give them a call a little later today
love this build dude. where did you get your poly windows? I've looked at a few. are yours molded to the window shape or flat and need bent?
Dam... This is well impressive! :)
They're the ones from phil j and they're flat, I looked at a few myself but the closest to phil j's price was still double the price
thanks :-) waiting for some decent weather so can take some more pics for more updates
Cheers for the info. Phil never messaged me back. I need cast ones tho :(
  • 3 months later...
My one productive day over christmas
will be smoothing them in at a later date rather than keeping the bolt on look
Nice work mate, like the rims too
nice build,will defo be keeping an eye on this thread
Cheers lads, just hope i get chance to get some more done this weekend
Went on a bit of a road trip earlier, came away with these
20140104_195235_RichtoneHDR_zps175dc1c4.
ordered side mounts and harnesses as soon as I got home
Top seats them.
Side mounts and harnesses have now arrived, spent Saturday stripping the interior so it now consists of the dash and cobras, sunroof will also be coming out when I've found a blank that doesnt cost the same as a kidney, failing that made one, got a bit carried away with it so haven't got any pics yet.
Also discovered the bolt that makes sure the steering column doesnt seperate from the steering rack is missing and has been since before I bought the car
Proper build this pal, some great fab skills :)
Surely youve got to go turbo now you have mega squirt!!
I'm unsure which way to go at the minute, it does keep crossing my mind, but i always end up going back to the idea of supercharging it, just love the whine from a supercharger, toyed with the idea of throttle bodies but for the setup id want it would cost similar to supercharging or turbo'ing it for much less of a gain
