Newly built, Heavily modified 1300 HK engine
hey guys
Well since picking up and AFH conversion this will be surplus to requirements.
where do i start,
its a HK 1300 mech head engine fully rebuilt with new seals/gaskets etc
its also had/got:
New rings
one brand new piston(due to skirt damage)
new big end and crank bearings
a light hone
ported and polished head
block decked by 1mm to raise compression
full bottom end balance to what the engine shop call race spec(slightly higher tolerances)
its been run for less than 10 miles so still needs running in tbh
i also have a set of zx6r carbs and manifold which are on it which have been rejetted by bogg bros to suit.
not quite sure what to price it up for, i now how much its cost me!!!!
unfortunately i never got around to finding a cam for it but i reckon with a cam and a good set up it could make 100hp easy!!
ok so I'm thinking £250 for the engine alone, no box, flywheel or carb set up
or £300 with the carbs
anyone interested?
J
http://www.clubpolo.co.uk/forum/index.php?...c=93264&hl= some details here
ps il sort some pics this weekend
Edited by Rod Stylz
  • Replies 16
  • Views 668
just to explain why i chose this engine over a gt motor
i wanted the higher revving capabilities of the mech head!!!
Would you sell the bike carbs and manifold seperate?
Phil
do you recon it would run a nice 8500rpm once cammed and on differnt valve springs and maby with eleki ignition?? surley u could get more than 100bhp???
pmd
Oh yea it prob would make more i was just being conservative,
I reckon it could be a really quick motor once run in, plus iv done all the hard work for whoever buys it!!!!
Sorry phil atm id like to still be able to offer it as a package.
haven't recieved a pm josh??
can i also clarify this has the standard cam fitted atm and is a fully running engine!!!!!!!!
any idea of price?
well i guess id like at least £250 for it but that would be without the carbs and inlet.
is the inlet a bogg brothers manifold
no its one i made with a friend, i got a flange laser cut from a template i made then welded on stubs for the silicone hose, not quite as shiney shiney but does the job just as well!
Any idea what compression ratio it is at the moment?
never really had the chance/time/knowledge to figure it out tbh,
but by the way it cranks over and has next to no over run after switching it off id say it must be pretty high.
Edited by Rod Stylz
bumpski
nobody want this?!!!
how much just for the carb setup
boing!
Prov Sold
