Water collecting in spare wheel space.
Water has been collecting in the spare wheel well in the boot beneath the luggage compartment. What can have caused this? Has this happened before to anyone ? What is the solution ? Thank you.
  • Replies 12
  • Views 1.9k
Could be condensation.
Give the boot well a good clean and dry out, and if teh carpet is soggy take it out and let it dry out properly.
If its not condensation then it could be the weld on the bolt that holds the spare wheel in, if theres a bit of rust around it then it could let moisture in from outside, spray etc.
mk4? tighten the rear light bolts
Thanks I'll give it a try.
defo lights or seal on boot lid
That will give me something to sort out. Thanks. Gerry.
I have the same problem, I checked under th ecar and there's a bit of a hole which is obviosly letting the water in...check under the car you'll see the hole that probably where it is coming from!!
This happened to me. I vaxed my whole car and left it to dry with the windows closed. everythink steamed up even in the boot.
Thanks I'll check it out.
drill a hole in it lol prolpey your lights mine leak
If you've got a sunroof, check your drainage pipes are draining where they should be (I'm not sure where they are on specific models), this is a problem a friend had with a Nissan Sunny Coupé, a blocked pipe was backing up and draining into the boot, giving him an in-car pond. If you've not got a sunroof, try what everyone else suggested :)
