6n rear plate fixings
Hi, Just confirmed my private number plate e.t.c and going to swap them over very soon.
The front plate is no problem, take off and replace. However the rear plate has weird fixings and I cant figure out how I'm going to fix my new plate without devouring it with a drill. Somebody here must have come across the same problem?
I don't want to put big holes in my new plates.
  • Views 907
Sticky pads number plate companies sell really strong ones. ;)
The rear plate fixings aren't flat like the front ones so if you buy sticky pads make sure they're thick ones, Halfords sell sticky number plate pads, 6mm ones will do for the rear whereas 1mm will do for the front.
^^^ probs the best way or if you cant get the old screws out, drill them out and put some self self tappers. velcro can be done aswell but i dont rate it
