1999 1.0L Polo Thermostat
Hi, I'm new here and obviously "old school" , I've not kept up to date with the newer cars (I'm sure it shows) but where is the thermostat on my 1999 (V reg) Polo 6N? There was a time when a thermostat looked like a brass "flying saucer" complete with heavy duty spring but now who knows, is it easy to change? it was so easy to spot in the "good old days" follow the top hose until you came to a alloy housing (2 or 3 studs) and inside was, yes you guessed it, one brass thermostat, so let me into the secret, where the hell is it and what does it look like?
Thank's in advance, Tony.
  • Views 997
they are pretty easy to do. if you have an engine cover take that off and its on the right hand side of the rocker cover, have a look buddy!
engine thermostat, coolant lines, coolant level: You should have no trouble as long as the needle for the temperature is moving, and staying in the normal,
_________________
Thermostat
welcome to the mad house matey!
Shouldnt be too hard to find once you get the engine cover off.
