Problem
hi all, bought a mk4 polo 1.6 at the weekend,
it starts great first time but then if i turn the engine off or if it stalls then for some reason it wont start up again?
it doesn't even sound like its trying really. anyone know what it could be or why its doing it?
cheers Josh
  • Replies 13
  • Views 1.2k
anyone?
yea that happens to my polo but i hant got a clue what it is mate
its been about 2 hours since i had it going at it still wont start
could it be the battery????
can be a number of things mate. if it dosent turn over but u can hear it trying then its most likely a flat batterry in which you need to check its ok or check your alternator e.t.c
could be the battery not having enough power to start the engine which probs means your alternator aint charging the battery. if not that could be starter motor
cheers for the replies
do you know what it was just out of curiosity?
is the engine turning over when you turn the key?
hard to explain, like say if i went out in the mornin to start it, i would start perfectly.. when i turn it off, got get a drink or watever come back and it wont start! i think it could be the battery i dnt really know
But how does it not start? Does it actually spin the starter motor? If not, then my money is on the ignition switch or immobiliser both of which can be problems with Mk4s.
Yeah, does it crank, as if its tired when you try to start it after youve just been driving? or does it just make like a click sound when you turn the key and thats all?
its all fine now i think, i think it was just a flat battery :) (hopefully)
