GT failed MOT
oh well was only minor this year rear brake cylinder leaking. and a steering gaitor he says. so not to bad. Was wondering if my cut springs would be a fail and my horn which works when it wants to but those were fine.
Cant use it till saturday as they have to order the part in and says one of the parts is GT specific so poop.
Having to drive around in the misus renault megane sport. but dont feel even slightly sporty . but gets me to work.
Anyone had a fail recently on minor things with there mk3 polos?
  • Replies 19
  • Views 1.5k
how on earth did he know the rear brake cylinder is leaking? They dont take the drums apart on an mot!?
ps if he's gonna change one u might as well change both of them
tell tale drips of fluid in rear wheel or drip of fluid at lower edge of brake assy - perfectly acceptable fail
Why change both, if one works fine? there £11 each btw!
it's gonna have to be pissing out for it to drip out of the drum, in which case there would be fuck all fluid left in the reservoir surely!? Bearing that in mind surely he would've spotted that long before the mot?
you wouldn't change just one disc would u? or one set of pads?? For £11 why take chances when it comes to brakes
Edit: it's gonna need rear shoes too if the cylinders have leaked
Edited by aroncmc22
How much are rear shoes? GSF or eurocar parts. are they GT only or they share the same as other mk3s?
A Cylinder and a disk are to different things lol. Whats the, why take the chance the? rear drums do 20% of the braking so if the cylinder goes on the other one replace it then, no point making more work and money when its not critical.
I cant remember offhand whether or not the cylinders are GT specific but creating a free account with vagcat.com will allow you to find out! Replace both rear drums as if one is more or less effective than the other it could make the car pull to one side slightly. Either way, the brakes are the only thing preventing you from piling into the car in front, or a wall, or pedestrian, so why take chances? For the sake of a tenner id rather have peace of mind that the other one isnt gona die on me and need replacing before long.
The way i see it, if something happened at a later date that i could have prevented by not being lazy or a cheapskate, i would be kicking myself for not sorting it earlier.
I agree with the case above, but in my case I accidentally knocked the brake cylinder off, so I'm replacing that one cylinder, before I knocked it off they were working perfectly, so I'm not going to replace the other Cylinder.
If the guys cylinder has been leaking a while, I would think about changing the other cylinder and the shoes aswell because brake fluid is corrosive isn't it.
Edited by PoloTommy
Ok cheers will have both replaced then. is a safety thing after all.
dont forget the rear shoes too as contaminated brake shoes/pads are useless.
The rear shoes are the same on all mk3s (and come in a box of four so no excuse for not doing both sides)
You want the wheel cylinders for model fitted with rear pressure regulator
Gsf part numbers:
wheel cylinder (you need 2) 65467
Rear shoes 63144
had to get some myself on monday :-(
Edited by aroncmc22
Gsf part numbers:
Rear shoes 63144
Weirdly I had to get some yesterday, if your bleeding the brakes don't jack the car up due to the rear pressure regulator.
I must admit i've not heard that before?
Same! well thats what a mechanic told me, it could be bullshit but he said its has some sort of system that takes into account the weight of the car, so its important not to jack the car up. :S
Hmm, could be true you know. Can anyone clarify for definate?
Shouldn't make a difference when bleeding as all your doing is getting the air bubbles/old fluid out.
but as aronmc22 said it could be true.
agree with Cymro, shouldn't matter when bleeding. and you have to jack the car up to get the the bleed nipple anyways
